i took my timer off to clean, and when i put it back on, and all the wires, and tried to start it, it would not start and the carburetor started backfiring. any ideas? its a tiger timer.
thanks,
carson
timer problems
Re: timer problems
My guess would be that you got a wire or two in the wrong place.
Be sure all wires are in the right place.
While you're at it, check the timing: http://dauntlessgeezer.com/DG97.html
MKossor
- First Name: Mike
- Last Name: Kossor
Re: timer problems
Did you remove the roller? Some CAM shafts are drilled all the way through allowing the roller to be installed 180 degrees off (i.e. Backwards)
Mr man
Topic author - Posts: 67
- First Name: Carson
- Last Name: Combs
- * REQUIRED* Type and Year of Model Ts owned: 1924 touring, 1923 roadster pickup project
Re: timer problems
yes, it turns out i had the roller backwards!
thanks for the help guys
