13T - What is this mod?
Darin Hull
First Name: Darin
Last Name: Hull
* REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
Board Member Since: 2010
Post by Darin Hull » Sat Sep 19, 2020 11:30 am
Hello,
I was oiling up the T and for some reason saw something I missed before. It’s a cable attached to the bar underneath the T operated by the hand brake. The cable goes back to the rear drums. This looks like some type of mod to the brakes... my grandpa was known for such things.
Looking at the pics. Can someone tell me what he was doing, if I need to change something, etc? This may be a case of a dumb question if the answer is so simple. Unfortunately, I’m not sure what’s going on as the hand brake bars are still present.
Thank you, Darin
Les Schubert
First Name: Les
Last Name: Schubert
Re: 13T - What is this mod?
Post by Les Schubert » Sat Sep 19, 2020 11:40 am
AC rear accessory brakes?
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sat Sep 19, 2020 11:48 am
Looks like AC or AC style brakes hooked up to the hand brake lever. I have AC brakes on my 1911 hooked up that way.
Last Name: Wrenn
Post by TWrenn » Sat Sep 19, 2020 4:00 pm
Darin, I suspect Gramps wanted a superior type of "parking brake" as sometimes the stock brake doesn't do too well, especially if it's not adjusted properly. Also, of course, it could be used occasionally as a good service brake also.
