Old Photo. I'm trying to date this tornado-damaged Model T
Mark Nunn
Topic author - Posts: 1293
- Last Name: Nunn
I found this photo that was taken on May 12, 1913 after an Easter Sunday tornado.
It has a 6-rivet rear axle housing, which puts it earlier than July 1911.
The other photos show interesting details. There is a cutout pedal on the left.
I tried to get a close up of the radiator hose and cap. The hose clamp looks different that those I have seen. And the fins on the radiator cap seem thin to me. It also looks like the lamp has "Ford" on top.
What do you think? I can get other detail images if anyone wants to see more.
Re: Old Photo. I'm trying to date this tornado-damaged Model T
As interesting is what's in the box behind it! Boom!
Mark Nunn
- Last Name: Nunn
Mark, the box looks like it was a wagon with "...TRUCK CO" on it. It has a bunch of cast iron window sash weights in it.
Ah man your taking all the fun out of it!
- Last Name: Wrenn
I was gonna say the same thing about the window weights. Had my share of trouble replacing the cords on those cussed things long ago. But you beat me to it!! LOL
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
It looks to me like the 2 piece dash has the brass trim that wraps around the wood, so I am thinking 1911.
R.V.Anderson
- First Name: R.V.
- Last Name: Anderson
The coilbox has the small Kingston switch. The first ones were fiber but they were soon replaced with brass. Hard to tell for sure which it is, brass or fiber, but either way, the small switch was replaced with the large, round, hard rubber switch just before the end of the 1910 model year, so I'm going to say the car's a '10.
OldFord
- Last Name: Iaccino
You gotta wonder if the poor guy who owned it stalled it on the tracks and had enough time to jump, let alone get out and crank start it... Dang, it was probably brand new...
Frank
I just re-read the post, tornado, not train...
Frank
Walter Higgins
- First Name: Walter
- Last Name: Higgins
- * REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout
Lots of things point to 1910 -- the curved profile on the lower portion of the door, the style of radiator cap, the Jno Brown 60 sidelamp, and the buggy rail on the rear seat.
Herb Iffrig
- First Name: Herb
- Last Name: Iffrig
It looks like butterfly rear fender irons are on it to me. I'll go with 1910.
kmatt2
- First Name: Kevin
- Last Name: Matthiesen
I will go with 1910 : buggy rail, butterfly fender iron, etc as above. Also I think a red car would photograph darker and green would photograph about like this car, even though car is dirty. I bet that the chassis was repurposed for farm use and lived on for some time in farm use.
Aussie16
- First Name: Warwick
- Last Name: Landy
- * REQUIRED* Type and Year of Model Ts owned: 1916 RHD Canadian Touring 1916 Pickup 1926 Fordor 1925 Dalgety Tourer 1916 Speedster
Another clue, low filler neck on radiator. 1909/10 for sure.
