'26-'27 body blocks
Mustang1964s
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
'26-'27 body blocks
Post by Mustang1964s » Thu Sep 24, 2020 10:13 pm
I found a bunch of body block for a '26-'27 T in my father-in-law garage.
Trying to research where they belong, it seems that go on a roadster or coupe.
Does the touring car need blocks?
If so, where can I find where they go? I have been under the '26 T, and have not seen any place for blocks.
I am replacing all the interior wood and have a lot of left over pieces. It seems that the T is either a really late '26 or a '27.
Thank you,
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Re: '26-'27 body blocks
Post by Altair » Thu Sep 24, 2020 11:24 pm
The blocks go in between the frame at the rear engine mount so that you can tighten the rear engine mounts and not crush the frame. There will be a number stamped on the frame right under the passenger door that will tell you the year and month.
Roffe
First Name: Rolf
Last Name: Oehman
Post by Roffe » Fri Sep 25, 2020 6:13 am
I googled and found this on Antique Auto Ranch.
http://www.antiqueautoranch.com/montana ... yBlock.htm
