Cleaning an aluminum hogshead
Belliott3
First Name: Bill
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
Board Member Since: 2006
Post by Belliott3 » Thu Feb 21, 2019 7:51 pm
I need some advice on the best way to clean an early aluminum hogshead. My 1910 T has the square hole aluminum hogshead and it's pretty dirty (oily and oxidation). Aside from taking the hogshead off, what are some recommended cleaning options? I'd be grateful for any advice!
Ruxstel24
Last Name: Hanlon
Re: Cleaning an aluminum hogshead
Post by Ruxstel24 » Thu Feb 21, 2019 8:06 pm
If you have a transmission shop nearby, most of them have a hot tank/pressure washer.
They do an amazing job on aluminum. About half an hour in there and spotless !! Bring em a 12 pack and see what happens...
About the only thing I miss about the dealerships...well, and the pretty girls too :D
tdumas
First Name: Ted
Last Name: Dumas
* REQUIRED* Type and Year of Model Ts owned: 1927 Coupe, 1924 Touring
Post by tdumas » Thu Feb 21, 2019 8:12 pm
Take it to your local do it yourself car wash and use the pressure hose and soap.You might spray it with Gunk first.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Thu Feb 21, 2019 9:22 pm
Barkeeper's Friend. Available at Walmart and other grocers.
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Thu Feb 21, 2019 9:53 pm
I just tossed my 15 hogs head in dish washer add soap and ran it through a cycle with soap
Job done
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Thu Feb 21, 2019 10:11 pm
Solvent de-greased, blasted with fresh #6 glass bead, and followed up with fresh #13 glass bead.
Last Name: Wrenn
Post by TWrenn » Fri Feb 22, 2019 9:57 am
Lacquer thinner, parts cleaning brush, lots of rags, and a bit of patience. Works for me. I don't have the availability of a way
to have it blasted, and probly am too cheap to spend the money on it anyway. Sooner or later even a nice clean hogshead is
gonna get all pigged up anyway. It's just the way a T is!
Marc Roberts
First Name: Marc
Last Name: Roberts
* REQUIRED* Type and Year of Model Ts owned: 1914 Runabout, 1916 Touring
Post by Marc Roberts » Fri Feb 22, 2019 11:18 pm
On the car, use Dawn dish washing liquid and an old toothbrush for the oil and grime. Not sure what if is strong enough to clean the oxidation to suit you, yet safe for everything else adjacent to the aluminum. The oxidation may not be pretty, but is it probably a protective layer.
TFan
First Name: Jim
Last Name: Riedy
Post by TFan » Fri Feb 22, 2019 11:50 pm
I don't know if they still make it, but I used to have some "Aluminum Naval Jelly" I think it was made by Duro Co. that would clean up a degreased but stained hogshead I would think. Jim
