Brake drum thrust washers Question
lorenzo26
Topic author - Posts: 50
- First Name: lorenzo
- Last Name: leon
- * REQUIRED* Type and Year of Model Ts owned: 2 doctors coupe
I have the the gear shaft and flywheel on crank ready to go , but i cant get the thrust washers to go down on the flywheel hole all the way down i dont want to force them in , Question -can i grind the edge of the 3 washers down some to fit them in ? Thank you for any info--
Lorenzo
Lorenzo
Re: Brake drum thrust washers Question
No thrust washers go in the flywheel hole. Maybe a photo would clarify what you're asking.
lorenzo26
- Last Name: leon
pictures this is a 26 trany
- Attachments
- 100_1494.JPG (125.36 KiB) Viewed 2423 times
- 100_1496.JPG (137.53 KiB) Viewed 2423 times
The best thing to do is read the Ford Service book! The reason those washers won't fit is because they don't go there!
That's NOT where they go - they go on before the clutch drum !
lorenzo26
- Last Name: leon
Yes thats right,. Thank you all for the input
Use the MTFCA Transmission book and/or Mike Bender's Model T-Tips videos on YouTube.
Wrong location. I use the Ford service manual when I put a T transmission together. Or at least refer to it before I put a T transmission, differential or engine together. I’ve rebuilt a few T components but a refresh of what I’m going to do keeps me from doing the wrong thing. Been there and done that.
