Best Way To Display Used Tranny Drums...
Topic author - Posts: 2888
- Last Name: House
...for sale. I’m disassembling Model T transmissions primarily to salvage reusable drums to sell. It’s surprising how many are cracked - they go into the scrap pile. I’ve begun to ospho a few drums after beadblasting then neutralize with Arm & Hammer with water. Then I began to wonder if that’s the best way to preserve them for others to use. Cover with oil and place in sandwich bags ? What think you ?
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
Re: Best Way To Display Used Tranny Drums...
Not sure why you rinse them with baking soda, The glass beads present no issue. Gibbs Brand is a great product to keep them from rusting after clean up.
- First Name: Steven
- Last Name: Sebaugh
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
I also use Gibbs or 140w oil to coat my parts. Then I put them into zip lock bags. Last I use a 3 x 5 card with the name of the item and the specifications of the part so I do not have to measure it again to see if it is a good part. If you do this procedure, the part is protected and ready for use if you need it.
1924 Model T Touring
1924 Model TT Truck
1928 Graham-Paige model 619
1930 Model A Phaeton
1924 Model TT Truck
- First Name: DAN
- Last Name: MCEACHERN
Be aware that cracked drums might have good gears attached and those should not go in the scrap bin.
- Last Name: House
Very good Steven and Dan...I will NOT throw good T parts away so I’ll now separate the gears from the cracked drums. Thanks for the idea ! And from now on it’ll be oil in a gallon ziplock bag instead of ospho. Another great idea.. thanks !
