Stumbled Upon this Youtube Restoration Series - Model T Fordor
Last Name: Strange
Post by CudaMan » Fri Oct 02, 2020 4:15 pm
I was browsing Youtube and stumbled upon this, part 1 of a series. I haven't finished watching the whole series yet. The use of the pressure washer on the interior and electrics gave me the chills.
https://www.youtube.com/watch?v=v929yjF2jrw
Last Name: Seth
Re: Stumbled Upon this Youtube Restoration Series - Model T Fordor
Post by perry kete » Fri Oct 02, 2020 6:12 pm
I watched the three videos that I could find on it and it mostly looks like a cosmetic restore job. They didn't do any disassembly they just painted clear over the rust with a brush and no mechanical work yet.
Last Name: Strange
Post by CudaMan » Fri Oct 02, 2020 6:39 pm
Yes, looks like a "doll it up and flip it" kind of job. He did mention "getting it running" as part of the plan in the first video. The new owner will have to undo a lot to do the job right.
That said, what is there will be better preserved under the layers of rust convertor and clear coat and the car will be back in circulation. :)
Post by Rich Eagle » Sat Oct 03, 2020 4:17 pm
I will say that the first video has some of the best detail of interior areas that I have seen. I can see how my rear floorboards should be in my Tudor now. I did cringe a little to see all that moisture going inside.
Last Name: Strange
Post by CudaMan » Sat Oct 03, 2020 4:57 pm
Did you notice the "Ford Faithful" oiling system transmission cover? I wonder if he has the rest of the system (I sent him a link to the kit on Lang's site). :)
thom
First Name: Tommy
Last Name: Coffey
* REQUIRED* Type and Year of Model Ts owned: '21 Touring
Post by thom » Sat Oct 03, 2020 7:28 pm
I think he needs to know not to jack up a T under the center of the rear end. I believe he jacked it up that way to put the stands under it. :(
vping
First Name: Vincent
Last Name: Pina
Post by vping » Sat Oct 03, 2020 8:36 pm
What is the best way to Jack it up. One side at a time?
Last Name: Strange
Post by CudaMan » Sat Oct 03, 2020 9:05 pm
Jacking one side at a time out near the wheel is fine, or you can make a cradle like some shown in this older thread:
http://www.mtfca.com/discus/messages/70 ... 1500086106
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Mon Oct 05, 2020 8:52 pm
That guy just found out the car is full of termites
William L Vanderburg
1922 Center Door Sedan
