how far do wood bows go into the top iron.
TBones12
Last Name: Poane
* REQUIRED* Type and Year of Model Ts owned: 1916 Hack, 1910 Touring, 1914 Touring, currently a Touring 1912, 1912 Torpedo Roadster
Post by TBones12 » Tue Oct 06, 2020 4:39 pm
I have top bows that are new repo's.
The ends are squared that need to be sanded to fit the irons.
The question is, is there a certain length that goes into the iron or do I just arbitrate 6 inches or so.
Thank you!
Re: how far do wood bows go into the top iron.
Post by Wayne Sheldon » Tue Oct 06, 2020 6:18 pm
Varies a LOT! Years, makes, models, outsource suppliers, quality and correctness of replacements, old repairs, alterations etc etc etc etc.
Regardless. What matters the most is the finished height/length/width of the entire top. If you have that information, the "slide-in fit" is done until the final desired measurement is reached.
If you do not have that critical measurement? Then you need to request that information, giving year and model/body style. (Here, we might assume it is a Ford.)
TBones12
Last Name: Poane
Post by TBones12 » Tue Oct 06, 2020 8:38 pm
Thank you Wayne, This is for a 1912 Torpedo Roadster. I have a 1912 Touring so I will see if I can estimate the fit-in length for the touring and emulate it for the roadster.
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Post by Altair » Tue Oct 06, 2020 9:46 pm
The front and rear wood bows go in deeper than the center bows, I am using 26 bows as a reference.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Wed Oct 07, 2020 12:44 pm
I am remote, so can't post a picture, but I think I have posted 12 torpedo top image.
Let Google be your friend.
TBones12
Last Name: Poane
Post by TBones12 » Wed Oct 07, 2020 3:05 pm
Thanks Ken, I'll check them out.
Higher top bow makes sense now that you mentioned it Altair.
Good thought process Wayne, thanks!
Post by Allan » Wed Oct 07, 2020 4:28 pm
Excessive height on the centre bow on a torpedo/roadster/runabout will make fitting the top cover without wrinkles at the side problematical. It does not need to be much above the rear bow in height, so that the measurement along the seam is comparable to the measurement along the side. Too great a difference will lead to the side flapping, requiring an unnecessary dart in the side to take out the slack.
Hope this helps,
TBones12
Last Name: Poane
Post by TBones12 » Wed Oct 07, 2020 5:43 pm
Makes sense, got it, thanks Allen!
