Ok, NOW is when that hardened sleeve 2596 replaces the hardened step in the driveshaft. This sleeve design continues through 1927.
***1911-1913 2 Piece Driveshaft Cross Section***
VowellArt
Topic author - Posts: 584
- First Name: Martynn
- Last Name: Vowell
- Board Member Since: 2012
Fun never quits!
Re: ***1911-1913 2 Piece Driveshaft Cross Section***
Looks like you should do some more research!
VowellArt
- Last Name: Vowell
Larry, probably so, but I'm rather limited upon what I can use for that research, even so, my work is basically given as "in progress" state. Meaning I will continually change them until I either stumble upon (whether by design or accidentally) the correct representation, so any help anybody can give me is greatly appreciated.
Fun never quits!
VowellArt
- Last Name: Vowell
Slight Change to spool and thrust bearing and bushing sleeve.
Fun never quits!
VowellArt
- Last Name: Vowell
Slight reconfiguration of the ball.
Fun never quits!
