Can I use ‘15 ribbed pedals on a T with a starter?
TorontoMD
Topic author - Posts: 92
- First Name: Tom
- Last Name: K
Are there by fitment/function issues using these pedals on a hogs head with a starter?
Re: Can I use ‘15 ribbed pedals on a T with a starter?
The parts book says 1909-1925 pedals are interchangeable. The ribbed ones were used in 1915 on US cars, but for many years in Canada.
Kevin Pharis
- Last Name: Pharis
Joe Bell
- First Name: Joe
- Last Name: Bell
The clutch arm on a non starter peddle is straight, the starter peddle has a bend in it to clear the bendix cover, I have used them but heated them to bend to clear the cover, hope this helps. Joe
Adam
- First Name: Adam
- Last Name: Doleshal
The clutch lever AND the low pedal are different between starter and non-starter transmission covers.
So I wonder why the parts books list the same pedals for 1909-1925. My guess is that the late pedals will work on the earlier cars, but not vice versa.
Kevin Pharis
- Last Name: Pharis
A RHD car may not know the difference...?
TorontoMD
- First Name: Tom
- Last Name: K
Thanks guys
Are the pedals cast steel?
