bailing wire nut?
Mustang1964s
Topic author - Posts: 272
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
bailing wire nut?
I ran across this front axle.
This is kind of scary, I just can think how things could have gone wrong.
bailing wire, talk about a field fix.
Dropacent
- Last Name: Morsher
Re: bailing wire nut?
Bailing wire is the JB weld of the 1920’s and 30’s
Mark Osterman
- Last Name: Osterman
I bet that car had a death wobble shimmy!
JohnM
- Last Name: Michaelree
- Board Member Since: 2010
A temporary although questionable fix to get you where you're going. On the other hand, it was probably put on there before you were born and it's still there
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
JohnM
Dang It! Where did you get that picture of me!!!
StevenS
- First Name: Steven
- Last Name: Sebaugh
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
The wire is probably all rusted up together tight, so ......... technically it is a rusted on nut.
I also think he, ......... "nailed it" ........ right as a good repair.
1924 Model T Touring
1924 Model TT Truck
1928 Graham-Paige model 619
1930 Model A Phaeton
1924 Model TT Truck
Hay seed repair, but at least the cotter pin is in place even if it's a nail!
Mustang1964s
I saw that and just had to post it.
Just when you think you have seen it all, then the Model T still surprises.
- Last Name: Strange
Remember, there is nothing more permanent than a temporary fix that works!
- Attachments
- red_green.jpg (16.39 KiB) Viewed 2365 times
