tractor conversion
Topic author - Posts: 10
- First Name: Condon
- Last Name: Story
- * REQUIRED* Type and Year of Model Ts owned: 1911 torpedo 1916 tractor conversion 1922 roadster 1923 hack 1926 4 door 1926 1 ton truck
tractor conversion
I have a staude mke-a- tractor conversion, How do you push a 11 to 1 geared rear end if it takes a notion it won't start?
- First Name: Adam
- Last Name: Doleshal
Re: tractor conversion
Gene, Pull the spark plugs, put it in high gear, and hand crank it...
