I pulled off the high head on my 1912 engine today and i noticed the engine is fitted with fully domed piston heads .
The domed pistons run approx 1/2 inch above the block deck. If i was to change to a low head could it become a mechanical catastrophe ?
Can i run low head using domed pistons
JohnnyBuick
Topic author - Posts: 86
- First Name: johnny
- Last Name: Buick
- * REQUIRED* Type and Year of Model Ts owned: 1912-13's
- Board Member Since: 2004
Shane Lach
- First Name: Shane
- Last Name: Lach
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor and 1921 speedster in progress
Re: Can i run low head using domed pistons
Yes that is what I have on my roadster.
JohnnyBuick
- Last Name: Buick
I just found this in the 2009 forum..
By Steve on Friday, October 16, 2009 - 09:55 pm:
I asked this same question a while back. 99% of the responders reccomended the stock (flat) pistons and then go with the high comp. head. You can not install a H.C. head with domed pistons.
I went this route, and I'm happy that I did.
...An idle mind is the Devils workshop
Les Schubert
- First Name: Les
- Last Name: Schubert
I run the high dome pistons with a low head on my 13. No problem and hand crank it.
BUT when building it, trial fit with no head gasket (and perhaps some plasticine on the potential “pinch points”) just to be sure of no “interference”!!
