Repairing a Broken Warford Case
Topic author - Posts: 5607
- First Name: Henry
- Last Name: Lee
Well this one was really imprignateg with oil. And, a vey porous casting to boot but success was achieved.
This fusion and blending was really testing my patiences.
I struck an oil well!
- First Name: Henry
- Last Name: Lee
Re: Repairing a Broken Warford Case
Using long pins to help stabilize.
Using JB Weld to seal off all the porosity at the weld.
Sealing the internal case with industrial varnish.
Anything is possible, just do not give up!
Tim Rogers
- Last Name: Rogers
Nice Henry!
Hopefully you have an "apprentice" that you are passing on all of your experience and methods to...
- First Name: Henry
- Last Name: Lee
Yes I do Tim. He is learning very well and taking it all in. Thanks for asking.
Hank
Hank
Nice job Henry!
I wonder how the casting broke at the flange like it did. Must have been dropped or the bolts got loose at the flange or? If it wasn’t dropped it could have been misalignment.
Adding the pins to help hold the flange together is a necessity in that location.
That’s as good a job as anyone could do!
- First Name: Dallas
- Last Name: Landers
The master at work! Thanks for showing us Hank. Always learning here.
- First Name: craig
- Last Name: leach
Hi Hank,
You did a fine job on that case. I'm sure glad you took that on. I don't think I could have done that nice of a job on it ever.
Way beyond my expectations. Thank you very much. Craig
Erik Barrett
- First Name: Erik
- Last Name: Barrett
Nice work.
- Last Name: House
Master craftsman Hank ! Used TIG ? Now speedshift it into OD going about 50. Good job !!
Kevin Pharis
- Last Name: Pharis
After learning the hard way on these old aluminum castings... I’ve begun heating with a torch till it sweats oil, then rinse and scrub with solvent. Repeat as many times as you have patience for, then break out the welder. Often the castings will also suffer from inter-granular corrosion thats impossible to weld, and must be ground out.
Kudos to anybody with the patience to tackle a repair like this
- First Name: Henry
- Last Name: Lee
Kevin did 5 heat sweat outs and washes and I still hit oil! One of the worst for me.
Hank
Hank
Kevin Pharis
- Last Name: Pharis
Like I said... as many as you have patience for
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
You HAVE to bake out the oil- all of it and it does take patience. Back in the days of vapor degreasers and trichlor, it was much easier, as those do a pretty good job of pulling any oil out. Also, the newer tig machines with adjustable duty cycles help a lot as you can set the duty cycle to clean the weld area. Older machines with a set 50-50 duty cycle can't do this. Fortunately I grew up a few blocks away from probably one of the best aircraft welders in California, and he was an absolute magician with a tig torch. Of course it helped to live less than a few miles from Naval Air Rework Facility Alameda where hundreds of skilled folks did their thing every day. To add to Bob's welding skills, he was a former BCRA midget driver as well.
