Safety Wire
Mopar_man
Topic author - Posts: 1191
- Last Name: Govoni
Safety Wire
So how do you like to safety wire you Mag Ring? Also when safety wiring the 4 flywheel bolts do you need to keep the amount of twists at a minimum so you don't have a bunch of wire on one side that will throw off the balance?
henryford2
- First Name: Joseph
- Last Name: Andulics
Re: Safety Wire
With the safety wire so close to the center of rotation I don't believe it will contribute to any significant unbalance. Just my humble opinion, enjoy. Joe
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: Safety Wire
Safety wire the field coil bolts in pairs as well as the flywheel bolts- no need to wire all four together in either location. And yes, as Joe said- the unbalance from any symmetry issues with the flywheel bolt wire would be minimal at best.
Mopar_man
- Last Name: Govoni
Re: Safety Wire
As always thanks for the advice.
