Front view of original 24-27 Ford TT Truck needed
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
Board Member Since: 2014
Post by SurveyKing » Wed Dec 16, 2020 1:43 pm
If someone out there has a frontal view of an original 1924-27 TT Truck, please post it here or email me. We are trying to match the radiator shield and fender apron and want to study original photos. Thank you
Last Name: House
Re: Front view of original 24-27 Ford TT Truck needed
Post by George House » Wed Dec 16, 2020 2:12 pm
Keep in mind the “radiator shield” (sheet metal panel covering the bottom radiator tank and through which the crank handle enters) is wider for a TT of 24-27 than for a Model T.
Post by Mark Gregush » Wed Dec 16, 2020 2:19 pm
Bunch of photos that you might be able to glean some info from; https://www.google.com/search?newwindow ... 80&bih=854
Even the older era ones, who knows what may have been factory or what might have been replaced. TT's restored today, could be 100% correct or 100% wrong re the radiator shell and fenders or even 50/50. ;)
Dan Haynes
Last Name: Haynes
Post by Dan Haynes » Wed Dec 16, 2020 2:34 pm
It's not a truck, but it's an interesting comparison of the prior low radiator next to the new high radiator.
kelly mt
Last Name: Kelly
Post by kelly mt » Wed Dec 16, 2020 2:51 pm
This is my 25 TT.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Wed Dec 16, 2020 3:24 pm
I like the two "supervisors" bringing up the rear. :)
1924 Touring
Post by Allan » Wed Dec 16, 2020 3:35 pm
Is there any reason why the TT apron should be different from the car aprons? The radiators are the same. The additional front spring leaf should have nil effect. Are the frame cross members different?
Post by DanTreace » Wed Dec 16, 2020 5:40 pm
T and TT front crossmembers are different.
TT is Ford part # 1122
Front of late TT with radiator apron
Or, right side up!
Post by Allan » Wed Dec 16, 2020 10:29 pm
Dan, the TT cross member looks heavier than the car one, but still the same basic shape. Is there a 9 leaf front spring Y mount with the hole for the extra mounting screw below the crank handle hole? Otherwise the standard radiator apron should still fit, as shown in the photos above.
SurveyKing
First Name: Daniel
Last Name: Snell
Post by SurveyKing » Wed Dec 16, 2020 11:18 pm
Thanks for the nice photos guys. Allan, sorry, I do not know about the engine mount difference if any on the TT. I was helping Julius Neunhoffer out on a project of his, but will ask him for you next time I see him.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Thu Dec 17, 2020 8:54 am
This photo was taken in '27 but I can't tell what year this TT was from.
