finishing firewall
DonH
First Name: Don
Last Name: Hanson
* REQUIRED* Type and Year of Model Ts owned: 1925
finishing firewall
Post by DonH » Thu Jan 07, 2021 10:47 am
Purchase 3/4" oak finished on both sides plywood to make firewall for my speedster build. Think I would stain with cherry and then a good coat of varnish. Does that sound appropriate? If not please give me some advise. Thank you, Don Hanson
Re: finishing firewall
Post by Mark Gregush » Thu Jan 07, 2021 11:54 am
It's a speedster, you can color it any way you like. :D Fine by me.
Post by TRDxB2 » Thu Jan 07, 2021 12:03 pm
Stain to go with the rest of the Speedsters colors. What colors?
Test your stain choice on a piece of scrap before you stain the firewall. The wood used for the display or brochure isn't your wood.
Post by Mark Gregush » Thu Jan 07, 2021 2:04 pm
Also, read up on staining oak/plywood. There may be some steps that need done before applying the stain so it does not get splotchy.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Thu Jan 07, 2021 2:26 pm
Hi Don, here bellow my original stock 1914 speedster project as well. It may inspire you.
Super Mario Bross ;)
1911 Touring
1914 Speedster
Post by Steve Jelf » Thu Jan 07, 2021 2:26 pm
I would use paste wood filler on that oak before staining. And yes, try your finish on a scrap before you do the firewall. Cutting out a firewall should produce plenty of scrap for practice.
DickC
First Name: Dick
Last Name: Cruickshank
Post by DickC » Thu Jan 07, 2021 5:24 pm
I don't consider myself an expert as I learn something from every project. I have been a finish carpenter for 30+ years and have built furniture and made several "firewalls" for T's and one for a 1911 cadilac. In all cases I used furniture grade birch plywood. Furniture grade plywood has up to 9 layers depending on the thickness. Birch plywood will usually take stain evenly and have a very nice even grain. Also in each case the edge of the plywood was covered. On the early cars, the edge was covered with a brass trim piece and later cars the cowell fit over the plywood. Be sure to coat both sides with the same number of applications and today there are several products using epoxy which in mho is best.
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Thu Jan 07, 2021 5:26 pm
Nice work. Does anyone have plans for a 1916 style that will have a brass square windshield?
DonH
First Name: Don
Last Name: Hanson
Post by DonH » Thu Jan 07, 2021 6:17 pm
Thank you all for your input, it really is helpful and the photos fantastic help!!! Don
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Post by Jack Putnam, in Ohio » Thu Jan 07, 2021 6:28 pm
If you are going to stain it with a cherry stain so that it will look like stained cherry, start with cherry veneer plywood. Oak will always look like an impostor. I use Minwax polyurethane finish which has UV protection. Let each coat dry for several days, block sand before the next coat. I usually use three or more coats of finish.
JohnnyBuick
First Name: johnny
Last Name: Buick
* REQUIRED* Type and Year of Model Ts owned: 1912-13's
Board Member Since: 2004
Post by JohnnyBuick » Thu Jan 07, 2021 9:48 pm
Don, These days you need to think out of the box !... Dont be a Lemming !!
I just stained my firewall few days ago in cedar on 1 side and on the otherside i went... gold baby !! Trust me the end result gets people crowding at the car shows , like bower birds they like shiney things ! Just Look at my last classy project :roll:
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Fri Jan 08, 2021 9:24 am
Johnny you did a fantastic job ! Congrats. How did you make the brass modling corner? I'm asking because I'm ready to install mine... :lol:
1911 Touring
1914 Speedster
Post by Original Smith » Fri Jan 08, 2021 10:29 am
Be careful what you get. As I recall, what they call 3/4", is really not true! It is 23/32" That makes for a loose fit for the brass trim.
JohnnyBuick
First Name: johnny
Last Name: Buick
Post by JohnnyBuick » Fri Jan 08, 2021 10:38 am
The brass framing around the firewall comes in lengths with pre drilled holes from most vendors .
With the thinner wrap material you can tuck it around the edges of firewall & the brass frame fits , hides & holds it in place ..
With thicker wrap it wont fold over the edges & can bubble up & lift around edges there ..but you can cut your wrap material to the firewall edges with a ultra sharp new box cutter knife .
Just be sure your surface is smooth as !! ..with no pimples etc before you wrap..
I stained & laquered to perfection both sides of the firewall so if any deterioration was to occur i can simply remove the wrap.
You can actually buy wrap in all colors of chrome these days & or other many textures ...also wrap that has different woodgrain textures too so you wont have to stain or laquer your firewalls... just wrap your firewall in your favourite wood grain texture.. 👍 its cheaper and more effective & with minimal labour too...
...An idle mind is the Devils workshop :twisted:
JohnnyBuick
First Name: johnny
Last Name: Buick
Post by JohnnyBuick » Fri Jan 08, 2021 10:45 am
Heres one or 2 examples...
s-l300 (1).jpg (13.27 KiB) Viewed 3638 times
Ray Syverson
First Name: Ray
Last Name: Syverson
* REQUIRED* Type and Year of Model Ts owned: 1913 Depot Hack
Board Member Since: 2010
Post by Ray Syverson » Sat Jan 09, 2021 11:49 am
In my experience the oak plywood is easier to stain and finish than birch or cherry, which is more prone to showing blotchy areas when stained. So oak is a good pick. If I were you I would definitely do some testing on the scraps you have, following the directions for both the stain and the varnish. Make sure you let the stain dry thoroughly. Stain and varnish separately-don't use varnish-stain mix. Plug up any holes in the firewall before you varnish, so the varnish doesn't drip or seep down to the other surface.
