Hey all,
I am looking to buy the hub thread chaser.
Number by Lang is 2815T, by Snyders T-2815-T.
Does any one out there know where I can buy one , on both places it is backorder and no date to be available again.
Andre
Belgium
Tool 2815T
AndreFordT
Topic author - Posts: 563
- First Name: Andre
- Last Name: Valkenaers
mtntee20
- First Name: Terry & Sharon
- Last Name: Miller
Re: Tool 2815T
Andre,
I do not know if these are available in Belgium, but you might find a "thread file" that has the correct number of teeth for your needs. I have used thread files often and have had good luck with them in many applications. Each one has 8 different tooth sets, 4 on each end, so be sure the file you get has the thread count you need.
Good Luck,
Terry
Good Luck,
Terry
