Atwater Kent type CA Front Plate Distributor - Rotor ??
DustySpokes
First Name: Edmund
Last Name: Niedzielski
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Post by DustySpokes » Thu Feb 04, 2021 1:59 pm
IN cleaning up my shop and getting things organized , I came across an old project that I forgot about. I have a cast iron, Atwater Kent front plate distributor ( slanted shaft ) that is pretty complete but is missing its rotor. It has the CA type cap with one side that is flat ( not rounded) and has threaded top connections that employ bakelite thimble screw- on wire holders on the cap. Can anyone in T accessory land post a picture of what the correct rotor looks like ? -Thanks ! - Dusty
