T bucket radiator for '25 restoration
Herr_Wiebold
First Name: Brett
Last Name: Wiebold
Post by Herr_Wiebold » Sun Jan 31, 2021 6:23 pm
Has anyone used the aluminum "T-bucket" hotrod radiators on a period style T? I'm looking at getting a new radiator for my '25, and 200 bucks is a heck of a lot more palatable than 800...
Like these:
https://www.ebay.com/itm/For-1917-27-Fo ... Swjyhew0wr
Re: T bucket radiator for '25 restoration
Post by John kuehn » Sun Jan 31, 2021 7:08 pm
If you want to restore your T to a stock appearance motor wise you will have to relocate the top outlet and either remove the automatic transmission line fittings for a more correct appearance. And maybe some more alterations if need be. It won’t just drop into a stock original T. The add is sort of misleading because it says Model T until you start looking at it and ‘read the fine print’. It’s made for Hot Rod use exclusively.
If you can tig weld that’s a plus since it’s made of aluminum and you can make the alterations yourself.
It’s been done by some here on the forum and you can do a search and read about them.
The radiator is made of aluminum and not copper so that’s a difference if it matters to you.
Don Lyon
First Name: Don
Last Name: Lyon
* REQUIRED* Type and Year of Model Ts owned: '24 Roadster
Post by Don Lyon » Sun Jan 31, 2021 8:26 pm
One thing to remember is most T bucket radiators are cut down (shortened). Don.
been there, broke that
Post by TRDxB2 » Sun Feb 07, 2021 1:26 pm
Just stumbled across this in Model T Ford Fix https://modeltfordfix.com/a-dirt-cheap- ... -model-ts/ :roll:
Post by John kuehn » Sun Feb 07, 2021 1:37 pm
There are probably more radiators for autos that would come pretty close to fit a T radiator shell besides the Mustang radiator. That’s an alternative for sure and it does work.
Last Name: Hjortnaes
Post by DHort » Sun Feb 07, 2021 4:18 pm
It would be nice if we could get Speedway Motors in Nebraska to order a batch with the correct inlets and outlets. They sell a lot of t bucket parts and have a Speedster reunion at the museum every other year. I also need to recommend you all go visit the museum. It is huge and awesome.
Wonder how many would be a minimum order and how many of us would purchase even if we don't need it at the time?
