What safety wire?
What safety wire?
Post by Steve Jelf » Fri Feb 19, 2021 2:00 pm
The .020" safety wire I have is too easily broken to suit me. Of course no local stores sell safety wire of any size at all. So before I go shopping online I'll ask here. What do you old hands at Model T reassembly recommend?
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Re: What safety wire?
Post by FATMAN » Fri Feb 19, 2021 2:20 pm
Menards has some good stiff wire that ties and twist pretty good, Bob
Post by RajoRacer » Fri Feb 19, 2021 2:25 pm
Aviation stainless steel - comes in assorted gauge.
Post by Steve Jelf » Fri Feb 19, 2021 2:33 pm
Yes, that's what I have, but the .020" is too easily broken. That's why I asked. What size works best?
Pep C Strebeck
First Name: Joseph
Last Name: M
Post by Pep C Strebeck » Fri Feb 19, 2021 2:51 pm
I have always used the 0.041" diameter wire with no problems, it works/fits for every location on the T. I definitely would not use anything less than the 0.032" diameter wire, but I prefer the 0.041" diameter. As you have stated, the 0.020" diameter will break too easily.
Last Name: Hjortnaes
Post by DHort » Fri Feb 19, 2021 2:53 pm
Adam told me to get the 0.041, so that is what I have.
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Fri Feb 19, 2021 3:02 pm
Steve, In a pinch and if you can't get what you want locally try a building materials store that sells rebar. They should sell wire for tieing rebar. I don't know if it will meet your needs but you could check a local store. I have a large role of stainless steel safety wire I bought at Harbor Freight and it lasts a long time, so where ever you buy it on line get enough to last a while.
Rajo23
Last Name: Goertzen
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring, 1927 Runabout
Post by Rajo23 » Fri Feb 19, 2021 3:05 pm
Try this:
https://shop.vansaircraft.com/cgi-bin/s ... afety-wire
Full disclosure: I have the pleasure of working at Van's.
Post by Steve Jelf » Fri Feb 19, 2021 3:19 pm
Excellent! There's a HF store just a half hour down the road. That will save me some time. Thanks to all.
https://www.harborfreight.com/search?q= ... ock%20wire
otrcman
First Name: Dick
Last Name: Fischer
Post by otrcman » Fri Feb 19, 2021 3:29 pm
Aviation safety wire as mentioned by others is good stuff. It is quite malleable and not as prone to breakage from twisting as other wires. Since we're talking aviation grade stainless safety wire, a good size guide is the FAA aviation mechanics manual AC 43.13-1B. Here is what the good book has to say:
"b. When using double-twist method of safety wiring, .032 inch minimum diameter wire should be used on parts that have a hole diameter larger than .045 inch. Safety wire of .020 inch diameter (double strand) may be used on parts having a nominal hole diameter between .045 and .062 inch with a spacing between parts of less than 2 inches. When using the single-wire method, the largest size wire that the hole will accommodate should be used......."
Notice that there is no specific mention of .041 wire in that paragraph, although the .032 is specified as a miniumum. The only specific mention of .041 is in the section on safety wiring cable turnbuckles and propellor mounting bolts. Since Model T's don't use propellors or control cables, you could just stick to .032 and be good to go.
Luke
First Name: Luke
Last Name: P
* REQUIRED* Type and Year of Model Ts owned: 1926
Post by Luke » Fri Feb 19, 2021 4:52 pm
@Steve Jelf - I'm a little interested as to exactly what use on your T this is intended for?
My reason for asking is that I seem to recall some discussion around lock wire disintegrating on gudgeon pinch bolts, hence people using split pins?
I've not looked, but I expect that discussion would be easily found. I've no particular view on this myself, but having used lock wire on many aeroplanes (without issue) I was interested to hear of this apparent issue.
If it is really a 'thing' then it seems to me it might be worth further research if you were intending using the wire internal to the engine.
jsaylor
Last Name: Saylor
Post by jsaylor » Fri Feb 19, 2021 6:17 pm
Luke: The only place externally to use safety wire, as far as I can remember, is the wishbone studs under the pan. You have to wire the two stud nuts together to keep hem from packing out of the pan. Internally there are several in the transmission and ring gear bolts in the rear end.
kmatt2
First Name: Kevin
Post by kmatt2 » Fri Feb 19, 2021 6:40 pm
Safety wire used on many more locations on pre 1921 cars. The closed driveshaft spool, the front engine mount engine pan nose cap are two that I can think of.
jsaylor
Last Name: Saylor
Post by jsaylor » Fri Feb 19, 2021 6:47 pm
Oh Ya. That closed drive shaft spool, studs instead of bolts. Out of sight out of mind.
Post by Allan » Fri Feb 19, 2021 7:53 pm
...and the two lower bolts at the fourth main.
The soft pliable wire used in wire tie hay balers is very handy. When not using it for safety wiring, it makes a good oxy welding filler rod. Just don't try using it for bailing out your boat. :D
It's Bill
First Name: Bill
Last Name: Hoffer
Post by It's Bill » Fri Feb 19, 2021 8:07 pm
Langs lists .040 stainless wire for a buck and a half in theit hardware section near the back of the (old) book. Cheers, Bill
Luke
First Name: Luke
Last Name: P
Post by Luke » Fri Feb 19, 2021 8:21 pm
Just in case anyone's interested I found a couple of the threads where (for gudgeon/wrist pins) the use of lock wire vs split pins vs lock washers was mentioned:
viewtopic.php?f=2&t=9272
viewtopic.php?f=2&t=6381
I wouldn't say it was discussed widely, nor in depth, however it's something that is perhaps worth thinking about.
2nighthawks
First Name: Harold
Last Name: Schwendeman
Post by 2nighthawks » Fri Feb 19, 2021 8:39 pm
Hmmm,....call me crazy, but somehow, the two terms,...."safety wire" and Harbor 'Freight don't quite sound quite right to me!
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Fri Feb 19, 2021 8:51 pm
I use .032" stainless steel aircraft safety wire throughout ... engine, transmission and rear end.
If you want a challenge you can use .041"
And if you are a glutton for punishment, use .062" :lol:
Respectfully Submitted,
Be_Zero_Be
otrcman
First Name: Dick
Last Name: Fischer
Post by otrcman » Fri Feb 19, 2021 9:47 pm
2nighthawks said
"Hmmm,....call me crazy, but somehow, the two terms,...."safety wire" and Harbor 'Freight don't quite sound quite right to me!"
I wasn't going to say it Harold, but dittos ! The real thing is only a buck more.
Dick
Post by Steve Jelf » Fri Feb 19, 2021 10:45 pm
The places I have in mind immediately are the four mag ring bolts and the four flywheel bolts. For the wishbone and the lower ball cap bolts I use the Standard Ford Repair Kit — ordinary baling wire.
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Sat Feb 20, 2021 11:09 am
Aircraft Safety Wire is annealed stainless steel, the annealing makes it less prone to fatigue and easier to bend without breaking
0.032 is most commonly used on Ts but 0.041 works fine too.
And try to buy or borrow the special pliers for it, it makes the work a lot easier and neater !!
Leo van Stirum, Netherlands
Post by Mark Gregush » Sat Feb 20, 2021 11:16 am
Funny how long the plain old type non stainless steel wire lasted for all those years! ;) Not all stainless is non magnetic, so you might want to check if first if you use. Yes I do use stainless on the inside, well most of the time.
jab35
Last Name: Bartsch
Post by jab35 » Sat Feb 20, 2021 12:20 pm
fwiw, when removing the differential from my coupe yesterday I found the bottom two ball cap-engine pan bolts 'secured' with two strands of #22 copper magnet wire. The wire plus vintage crud kept those tight. Not a recommendation. I see Lang's has small quantities of 0.040" safety wire in their catalog.
Post by Allan » Sat Feb 20, 2021 10:04 pm
Am I wrong in thinking that safety wiring is done to stop bolts/nuts from backing off? I cannot see how it can reliably maintain tension on the nut/bolt to stop it loosing tension. As long as the wire stays in place, it is doing its job.
Last Name: Patrick
Post by jiminbartow » Sat Feb 20, 2021 11:38 pm
Safety wire, if done right will maintain tension on bolts and prevent them from loosening. See: www.mtfca.com/discus/messages/29/48566.html. Jim Patrick
Post by Allan » Sun Feb 21, 2021 8:18 am
Thanks Jim. I can see how that will work, but I'd like to see evidence that that is how it was done on the production line. My gut feeling is that the safety wiring done on T's was just done to achieve the same result as split pins on castle nuts, to stop the nut backing off. We have the time to do it better when restoring, but it may be a case of over thinking it. This is totally understandable in the aviation industry where absolute safety is the pursuit. But, what might be the consequences of the two spring loaded nuts on the front wishbone backing off part of 1/6th of a turn?
