How do you attach the Strap to the Window on a TT Truck ???
StevenS
First Name: Steven
Last Name: Sebaugh
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
Post by StevenS » Tue Jan 08, 2019 9:30 pm
I have a Model TT Truck with the metal in closed cab. I need to attach the side window strap to the side windows to lift them up and down. My question is: How have you TT Truck owners done that? I need some good ideas. My side windows are safety glass. I have the strap and window, but no fastener.
1924 Model T Touring
1924 Model TT Truck
1928 Graham-Paige model 619
1930 Model A Phaeton
One390
* REQUIRED* Type and Year of Model Ts owned: 25 TT
Re: How do you attach the Strap to the Window on a TT Truck ???
Post by One390 » Wed Jan 09, 2019 6:51 am
http://www.mtfca.com/discus/messages/11 ... 1287615247
try this. you will have to get a little creative and fabricate the tab on the channel.
One390
Post by One390 » Wed Jan 09, 2019 7:12 am
I took my channel and made cuts at the corner in the appropriate spacing. I bent them out creating two tabs. I then took my piece of rod and mocked it up. I used rivets to final clamp my loop at correct length. I recall crimping the tabs down on rod but I might have braced one end. hope this helps. you get the concept anyway.
