Another question re: removing a 27 engine
rgould1910
Last Name: Gould
Post by rgould1910 » Wed Mar 13, 2019 1:18 pm
One more thing. My 27 has the headlight bar. I really don't want to remove it because to do so will break the paint on the bolt heads and possibly the fenders. I can't see how I can remove the engine trans assembly without removing the bar. Am I correct on this??
Chris Barker
First Name: Chris
Last Name: Barker
Re: Another question re: removing a 27 engine
Post by Chris Barker » Wed Mar 13, 2019 1:26 pm
I have a '27. I can't see how you can leave the headlamp bar in place - unless you lift off the whole body!
However, I don't see why the paint should suffer. The heads have square shafts beneath, so they should not turn. The nuts can be removed under the fenders, and then the bolts lift out.
I suggest you cut thick gaskets to fit beneath the bar ends above the fenders when you reassemble it. Other wise the bar could crack off the fender paint.
George N Lake Ozark
First Name: George P
Last Name: Clipner
MTFCI Number: 18665
Post by George N Lake Ozark » Wed Mar 13, 2019 1:58 pm
Just do it . I was concerned to but most fenders are prepainted before assembly . A little chipping on the bolt heads are normal and can be re painted.
Scottio
Last Name: Lay
Post by Scottio » Wed Mar 13, 2019 2:35 pm
X 2
Autie
First Name: Keith
Last Name: Keller
Post by Autie » Wed Mar 13, 2019 3:03 pm
Any time I don't want paint chipping, I take an X-Acto knife/razor and go around the edge of the part being removed.
infotfordnl
First Name: Bert
Last Name: van Amstel
Post by infotfordnl » Thu Mar 14, 2019 6:40 pm
Its not possible without removing the lightbar
Because of the starter handle (in dutch “de slinger”)
After taking out the bar it is not a hard job to take out the engine
If you have an engine lifter..
Nice movie of this Model T: https://youtu.be/jD1QJBZasdY
rgould1910
Last Name: Gould
Post by rgould1910 » Thu Mar 14, 2019 11:06 pm
Thanks for the help. The engine is out in the stand. I used an eye bolt in the second cylinder and a straight bar in place of the crank handle to tilt
the engine some to clear the pedals. It wasn't exactly an easy job but it is doable. Part of the difficulty was separating the Warford from the transmission. The light bar came out pretty easy and, as stated above, with only a little chipping of the bolt heads. Easy to repaint. Glad that part is over!
Never worked with a T with a starter/generator so I may have more questions.
