Welding peddals
RichJ
Topic author - Posts: 372
- First Name: Rich
- Last Name: Jesteadt
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
Welding peddals
For you expert welders what is best rod to weld replacement peddals to activating? Arms? I'm using DC stick machine.
Thanks in advance
Thanks in advance
RichJ
- First Name: Rich
Re: Welding peddals
I'm used 6013 don't like result
Herb Iffrig
- First Name: Herb
- Last Name: Iffrig
Re: Welding peddals
I would have done the same. Others might have used 7018 rods
got10carz
- Last Name: Meixner
Re: Welding peddals
7018 on DC. Slight preheat
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: Welding peddals
Just to add- cut the spliced area at a diagonal rather than 90 degrees to the length of the pedal shank as it will give you a much stronger joint.
RichJ
- First Name: Rich
Re: Welding peddals
Dan
I've done as you advise
Do you think nirod would be stronger than 6013
Re: Welding peddals
Use 1/8” 6011 rods. Run them around 90 amps. They will make you a smooth weld and better penetration than 6013.
Before you start to use your welder get you some scrap steel about the same thickness of the pedals and make some practice welds to set you welder to what’s suitable for you.
Some like to run a ‘hot weld’ using a little more speed than normal. That’s works OK if you are a experienced welder and know how to control your speed and heat. What ever you do practice a bit before you make the weld.
And do as Dan says to vee the joints a bit to give you a good weld.
Dan McEachern
- First Name: DAN
Re: Welding peddals
Veeing out the joint to get good penetration is also a good idea, but I was referring to running the actual joint itself at a diagonal in the direction from the shaft end of the pedal shank to the pedal tip.
Bob in ohio
- First Name: Bob
- Last Name: Gairing
Re: Welding peddals
Last summer I wanted to install new peddle pads and was told about the difficulty welding the new shaft to the old ones. I welded one, it looked good then tested its strength. It broke like glass right at the weld interface. For safety purposes I decided to carefully cut the short shaft off the back of the new peddle and then cut off the original right and left side of the original pad. The new pad was then welded to the complete original peddle shaft. With a little hand fitting the peddle curvature before welding you can make it look just like original. If it should ever break off at least the peddles will still be functional to get back home.
Kevin Pharis
- Last Name: Pharis
Re: Welding peddals
I’ve had good luck with stainless steel filler rod and TIG welding. Not sure how bout stick welding with stainless tho...?
John Warren
- Last Name: Warren
Re: Welding peddals
I will second 7018 rod. I would use 3/32 @about 90 amps. I have used it very successfully. 7018 is a malleable rod and is a perfect match with the pedal material. 100% weld is easily obtained by chisel shaping the joints, like said making the joint at an angle will make the joints longer and stronger. Be sure and grind into the back side of your first pass to achieve 100% Also alternate sides as you build it out. Use a needle gun if you have one to stress relief it. If not chip it well and use a sanding disk to finish.
