Can anyone verify the thickness and diameter of the lock washers that went on the fender eye bolts for a 12?
Mike
Verify hardware size for a 12
Re: Verify hardware size for a 12
Here is a little about early ones:
http://www.mtfca.com/discus/messages/50 ... 1446921280
I hope someone has more.
Tbird
Topic author - Posts: 1333
- First Name: Mike
- Last Name: Bird
Found some thick spring washers
The ones I've seen are much thinner than what's available today. Usually they are somewhat serrated as well.
