Wide brake drum???
Last Name: Hatch
Wide brake drum???
Post by Dan Hatch » Wed Jun 26, 2024 4:29 pm
I think I remember that a wide brake drum can be used in a 3 dip pan. Just can't use a wide brake band.
Is this correct or am I imagining it? Thanks Dan
Re: Wide brake drum???
Post by Allan » Wed Jun 26, 2024 7:41 pm
That's correct Dan. You can run the wide drum, with its attendant output shaft, in a 3 dip pan, but there is not enough room to run the wide band. Besides, that would mean changing the transmission cover too.
