Coil adjustment at Chickasha?
Topic author - Posts: 2838
- First Name: Dallas
- Last Name: Landers
Will there be someone there adjusting coils on sight?
RustyFords
- First Name: Don
- Last Name: Allen
Re: Coil adjustment at Chickasha?
I'd bring my ECCT and let anyone use it for free....but I'm pretty sure my spot won't have electricity access.
1924 Touring
MKossor
- First Name: Mike
- Last Name: Kossor
One thing to consider if coil adjusting at Chickasha is successful; be prepared to tightly wrap each coil in a sleeve of cardboard that extends above the coil points to protect them from getting bumped in transit home and observe care during coil box installation or all the effort is for naught.
Coil points are much more vulnerable to misalignment than most folks are aware. Properly adjusted coils must be handled and installed carefully following adjustment.
Here are the dimensions for making the protective cardboard sleeves: Secure with packing tap on Side, Top and Bottom. Will ensure save for shipping or transport without risk of detuning.
Rob
- First Name: Rob
- Last Name: Heyen
Good ideas, thanks Mike.
R.V.Anderson
- First Name: R.V.
- Last Name: Anderson
FWIW, I will have my coil test equipment at my spaces. NF 9 & 10.
I will stop and see you R.V.
RustyFords
- First Name: Don
- Last Name: Allen
I need to load up my whole car and bring it so you can look at the generator R.V. Anderson.
You rebuilt mine for me about a year ago and I can't get it to charge correctly.
1924 Touring
R.V.Anderson
- First Name: R.V.
Don, I don't rebuild generators; could you be thinking of Ron Patterson? I buy rebuilt generators from him. Wonderful work.
A few years ago I brought mine just to have Mike Bender drive it and listen to it.I need to load up my whole car and bring it...
RustyFords
- First Name: Don
- Last Name: Allen
Yes...sorry...old age kicking in at 52R.V.Anderson wrote: ↑Wed Mar 10, 2021 2:52 pmDon, I don't rebuild generators; could you be thinking of Ron Patterson? I buy rebuilt generators from him. Wonderful work.
1924 Touring
RustyFords
- First Name: Don
- Last Name: Allen
I remember that Steve. I saw you and Mike leaving the barn in it.Steve Jelf wrote: ↑Wed Mar 10, 2021 3:45 pmI need to load up my whole car and bring it...
A few years ago I brought mine just to have Mike Bender drive it and listen to it.![]()
1924 Touring
