***1926-1927 Hogshead Assembly***
VowellArt
Topic author - Posts: 587
- First Name: Martynn
- Last Name: Vowell
- Board Member Since: 2012
This one I'm not so sure of, so please look it over and let me know where any changes should be if any.
Fun never quits!
VowellArt
- Last Name: Vowell
Re: ***1926-1927 Hogshead Assembly***
Had to make a small correction on the Clutch Fork, in that the shaft and the linkage lever is forged as one piece.
Fun never quits!
VowellArt
- Last Name: Vowell
Small correction; forgot the part number for the Magneto Post 3279B.
Fun never quits!
varmint
- First Name: Vernon
- Last Name: Worley
thanks Martynn,
I put it in the same folder as the 26-7 transmission assembly.
Vern (Vieux Carre)
- First Name: Dallas
- Last Name: Landers
Thank you Martynn for all the time in research and drawings you put in.
VowellArt
- Last Name: Vowell
Dallas, not sure what research I do other than get input from you guys as to what goes where and how, the rest is whatever I know and that isn't even close to enough...usually. But thanks anyway.
Fun never quits!
