What's wrong in these photos?
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Wed Mar 17, 2021 3:38 pm
In 1948, my sixteen-year-old father took photos of fifteen or sixteen-year-old Darel Leipold's 1910 touring.
Darel is sitting in the car in the first photo, but the windshield is "schmootzy" so he's not very clear.
The first two photos show something that is glaringly wrong yet easily correctable. It is most noticeable in the second photo.
Hint: it is not the electric lamp conversion or the MotoMeter.
What is it?
Hudson29
First Name: Paul
Last Name: O'Neil
Re: What's wrong in these photos?
Post by Hudson29 » Wed Mar 17, 2021 4:41 pm
The first thing that comes to my mind is that the car is not sitting in my driveway right now.
Post by TXGOAT2 » Wed Mar 17, 2021 4:44 pm
Re: "Not in my driveway"... my thoughts exactly! At that age, I had to settle for old bicycles and a very worn out cast iron B&S lawnmover engine.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Wed Mar 17, 2021 4:48 pm
It doesn’t have one piece spindles and early front axle?
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Wed Mar 17, 2021 5:02 pm
It's actually very trivial and not meant to disparage Darel's car (he knows what it is).
Here is a hint:
Post by speedytinc » Wed Mar 17, 2021 5:09 pm
windshield backwards?
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Wed Mar 17, 2021 5:25 pm
Nope - nothing to do with the windshield.
halftracknut
First Name: randy
Last Name: lee
* REQUIRED* Type and Year of Model Ts owned: 1926 pickup
Post by halftracknut » Wed Mar 17, 2021 5:42 pm
the wheels and tires are two different sizes.......
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Wed Mar 17, 2021 5:49 pm
Nothing to do with wheels and tires.
It can be seen only in the first and second photos but not in the third photo/full side view of the car.
AandTman
First Name: Donald
Last Name: Vagasky
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster 26 Touring 25TT C Cab express 26 Ames Speedster
Post by AandTman » Wed Mar 17, 2021 6:04 pm
Well, there is only one side lite, and the headlight's rims are different side to side.
John iaccino
Last Name: Iaccino
* REQUIRED* Type and Year of Model Ts owned: 1911 Roadster, Open Runnabout
Post by John iaccino » Wed Mar 17, 2021 6:33 pm
Script on radiator is not 1910
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Wed Mar 17, 2021 6:57 pm
True about the radiator, but that is not what I'm looking for.
Refer to my hint above, "The Dating Game."
Michael Peternell
First Name: Michael
Last Name: Peternell
Post by Michael Peternell » Wed Mar 17, 2021 7:23 pm
Gas tax sticker in the window?
John iaccino
Last Name: Iaccino
Post by John iaccino » Wed Mar 17, 2021 7:30 pm
License plate reads A 1909. Car is a 1910
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Wed Mar 17, 2021 7:30 pm
Another hint.
This obvious "problem" is unique to the year in which the photo was taken, 1948.
tmagill
Last Name: Magill
Post by tmagill » Wed Mar 17, 2021 7:34 pm
license plate has 1909 on it
tmagill
Last Name: Magill
Post by tmagill » Wed Mar 17, 2021 7:36 pm
dang John beat me by 4 minutes
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Wed Mar 17, 2021 7:38 pm
On my phone's small screen it is hard to see anything clearly in picture one, but in picture two it looks like the car has the later 1919 spindle arms. The wishbone looks like the correct above axle pre 1919 type. Did the car have the wrong lenght steering drag link also ?
67pontiac
First Name: William
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring 1913 Roadster 1919 TT 1920 Huckster 1922 Touring 1926 RPU
Board Member Since: 2010
Post by 67pontiac » Wed Mar 17, 2021 8:16 pm
I saw the missing side light, the right door latch handle is horizontal in the first picture, but vertical in the second photo. It appears to have the one piece spindles, but a later front axle, notice the amount of clearance between the spindle and the axle. I don't know what that would have to do with the photo being taken in 1948 though. I guess I'm just not very good at this kind of "game".
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Wed Mar 17, 2021 8:20 pm
When I was typing my last post, John posted the correct answer.
The license plate says "A1909."
Years ago, Minnesota allowed car owners to request specific license plate numbers when registering their vehicles.
The "A" is passenger cars weighing less than 2,000 lbs.
Darel originally thought the car was a 1909; therefore, he requested plate number "A1909" when he should have requested "A1910."
67pontiac
First Name: William
Post by 67pontiac » Wed Mar 17, 2021 8:25 pm
The only other thing I can see that is "wrong" is the starting crank engaged in the crankshaft and not hanging straight down, again, that has nothing to do with the photo being taken in 1948. There is a fairly new 1946 Ford in the first photo, but not noticeable in the second picture.
67pontiac
First Name: William
Post by 67pontiac » Wed Mar 17, 2021 8:29 pm
OK, here's my last "guess". The photo is taken in a residential setting in 1948, but I don't see any power lines or telephone poles in the background. By 1948, most neighborhoods had visible power lines. This could be a rural neighborhood that is still "off the grid".
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Wed Mar 17, 2021 8:30 pm
I posted the correct answer above.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Wed Mar 17, 2021 9:03 pm
William Bennett:
The photo was taken in Richfield, MN which is a first ring suburb of Minneapolis. There was still some farmland in Richfield after WWII but it was steadily developed into residential into the early 1960s.
The reason that you don't see utility poles in the street is that the power and phone lines bisect the middle of the blocks; the utility poles are in the backyards or along the alley if there is an alley. Also, Richfield did not have street lights in the 1940s in residential neighborhoods so there were no light poles along the streets.
I grew up and still live in Minneapolis a couple blocks north of Richfield.
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Thu Mar 18, 2021 12:05 pm
Darn! Using the "Dating Game" picture clue, I was going to guess he didn't have a cute blonde next to him in the car. :lol:
in 1948 I wasn't even a gleam in my daddy's eye yet, not by a long shot, and my in-laws had just PCS'd from Trinidad to London...
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Thu Mar 18, 2021 12:39 pm
"The Dating Game" is what the late Minnesotan Tom Reese, who was very active in the AACA and HCCA and wrote a number of articles for both clubs' national publications, referred to the misrepresentation of model years in the antique automobile hobby.
Darel and my father attended Minneapolis Washburn High School. They were in the same homeroom - the "Sound Crew" which served as both the A/V and stage crew.
Darel and my dad are standing next to each other (back row, second and third from left) in this 1949 Washburn "Wahian" yearbook page. My dad was a senior (he graduated in 1949 at age 17). Darel was a junior.
Darel bought his first Model T in 1946 (the 1910 touring that he still owns) but my dad didn't buy his first T until 1948.
Second photo is of the same two "Washburn Millers" taken in May 2010, at the 100th birthday party for Darel's Ford touring in Excelsior, MN - my dad left, bearded Darel right.
On a side note: Royce N. Peterson's dad, Royce D. Peterson, lived near Washburn High School and my dad would occasionally stop by his house on his way home from school to discuss Model T Fords. Royce was in his early thirties at the time.
Washburn Leipold 1949.jpg (86.86 KiB) Viewed 5809 times
Darel 2010.JPG (72.28 KiB) Viewed 5809 times
Last Name: House
Post by George House » Thu Mar 18, 2021 1:46 pm
All y’all missed it. Erik said “glaringly wrong but easily corrected”. The left side Cowl lamp is ‘black and brass’.
It's Bill
First Name: Bill
Last Name: Hoffer
Post by It's Bill » Fri Mar 19, 2021 8:34 pm
Missing cotter pin in the drag link, driver side. I'll show myself out.
