ID Pinion Gear?
Last Name: Hatch
ID Pinion Gear?
Post by Dan Hatch » Wed Mar 24, 2021 4:29 pm
Does anyone know what this pinion gear fits? Same size as T but has straight ID with splines. Any idea? Thanks Dan
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Re: ID Pinion Gear?
Post by Dennis_Brown » Wed Mar 24, 2021 10:06 pm
That does not appear to be a pinion gear for a differential as the teeth are not tapered as in a ring and pinion set. The drive shaft end should be a larger diameter as a ring gear has shorter teeth on the outside and taller teeth at the inside diameter. It is possible your gear is from a transmission but not sure.
Last Name: Hatch
Re: ID Pinion Gear?
Post by Dan Hatch » Fri Mar 26, 2021 6:43 pm
Here is side view
