Fair price for 26-27 wheels?
Fozz71
Last Name: Chochole
Board Member Since: 2003
Post by Fozz71 » Sat Mar 09, 2019 11:14 am
Hey guys, I have a person selling 26-27 wire wheels and I am not sure what a good price for 5 would be? If they are clan and painted- what is fair?
Thanks,
Jim
Re: Fair price for 26-27 wheels?
Post by Norman Kling » Sat Mar 09, 2019 11:57 am
Usually about $100 each for a set of 4. About another $200 for the hubs. The hubs are hard to find and only used on those two years and then only on the ones with wire wheels. Unfortunately, many people use these wheels and hubs on other year cars and speedsters so they are expensive.
Fozz71
Last Name: Chochole
Post by Fozz71 » Sat Mar 09, 2019 12:18 pm
Thanks Norman!
Post by Mark Gregush » Sat Mar 09, 2019 12:36 pm
$100 to $125 would be ball park for wheels, but more like $400-$800+/- "GOOD" for hubs. If you look on ebay. make sure the ones you are looking at are true 26-27 hubs and not converted early hubs.
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Post by Jim Eubanks » Sat Mar 09, 2019 5:38 pm
Most wheels I have seen for sale are not tried for trueness. They wobble and will have to be straightened. Just ask any flebay seller if he has check his wheels on a hub to see if they run true.
KeithG
First Name: Keith
Last Name: Gumbinger
Post by KeithG » Sat Mar 09, 2019 5:55 pm
I agree with what was said above with a bit of further information. I suggest turning each wire wheel while holding it to see if you can hear rust moving around inside of the beads. Also look for flat spots on the outside edges of the wheels indicating that the wheel was run with flat or no tires. I've seen some like that and would avoid them. Also, good hubs sell for about $100.00 each. On the front hubs, look for cracks around the lug bolt holes and other places too.
Keith
Bill Dizer
First Name: Bill
Last Name: Dizer
Board Member Since: 2014
Post by Bill Dizer » Sat Mar 09, 2019 7:21 pm
The front hubs are noted for cracking,and having the bearing race mounting area wallowed out so the race won't stay in. The rear seal area can be worn out too. Also check the lug holes in the wheels to see about wear from being run loose on the hubs. Lug nuts are kinda pricy, as are hubcaps.
