What is this hole for?
NY John T
Last Name: Killelea
Post by NY John T » Thu Apr 01, 2021 10:14 pm
Hi All,
I just took off the heavily occupied (mouse nest) radiator of my 27 Tudor and noticed this hole in the front of the block (August 23). Can someone tell me what it's for and do I need to replace what ever was there originally? Belt tensioner?? Thanks,
John
Re: What is this hole for?
Post by Mark Gregush » Thu Apr 01, 2021 10:19 pm
The fan and pulley.
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Thu Apr 01, 2021 11:35 pm
That hole and the boss with the bolt next to the hole were used for the fan bracket and fan belt adjustment on a pre 1926 T. Your 1927 car would have used a timing gear cover with out that hole or boss from the factory. I assume your 27 car is using a 27 fan, mounted on the head water outlet to raditor.
Bill Coyle
First Name: Bill
Last Name: Coyle
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Post by Bill Coyle » Thu Apr 01, 2021 11:47 pm
Adding to what Kevin and Mark said. Your 27 T should have the fan and pulley mounted to the water outlet that bolts to the cylinder head. The belt adjustment is made by turning the eccentric which holds the pulley shaft.
Bill Coyle
NY John T
Last Name: Killelea
Post by NY John T » Fri Apr 02, 2021 9:36 am
Thanks so much for the comments. The engine is a 23 in the 27 Tudor. It has the fan attached to the water outlet pipe. Now I know. Thanks.
John
Last Name: Wrenn
Post by TWrenn » Fri Apr 02, 2021 10:07 am
That is one interesting looking timer. Be sure to open it up and inspect and clean it and even make sure it'll work!!
Post by speedytinc » Fri Apr 02, 2021 11:17 am
The late 26, 27 cam covers do not have the boss with bolt for fan bracket adjusting as mentioned. They still have the large hole take 1/2" fine bolt.
Post by RajoRacer » Fri Apr 02, 2021 11:53 am
Recto Timer - I've seen an ad for that one somewhere.
Post by Steve Jelf » Fri Apr 02, 2021 12:38 pm
One of the many aftermarket timers to go with the many, many, many aftermarket spark plugs. :)
