Ruckstell linkage
Tmooreheadf
Last Name: Moorehead
Ruckstell linkage
Post by Tmooreheadf » Wed Mar 31, 2021 9:16 pm
I am about to finish a Ruckstell in our 24 Touring. Everything is essentially done and installed with the exception of the linkage. Would anyone happen to have a basic drawing of that linkage? I have seen several different ways to do it. The ones I have had previously are just conduit cut to length, bent and then split at each end to allow for a clevis pin at each end. I guess I’m being lazy and could fit one trial and error method. A real drawing would just be so nice
Tom
Re: Ruckstell linkage
Post by speedytinc » Thu Apr 01, 2021 8:27 am
I make that piece by welding a clevis into 1 end & coupling nut in the other of 1/2" conduit. Use a piece of all thread(aprox 6") & another clevis. Makes for fine adjustment for shift lever top location.
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Post by Jim Eubanks » Thu Apr 01, 2021 8:42 am
Tom, It is my opinion that the midship support extends life of the shifter mech. on the rear end. Seems like most of the used ones need repair when you find them and I suspect they were run with no midship support on the rod. That may be something to consider when fabing a shift rod.
John Warren
Last Name: Warren
Post by John Warren » Thu Apr 01, 2021 8:57 am
Tom, I agree with both John and Jim. I also want to add the straighter that you can make it the easier it will be to shift. It will be less springy, the mid support will also help. Another thing, just preference, But I like the after market linkage that is mounted just aft of the emergency brake and the shifter comes out the same hole as the e brake. It makes it much easier to get in and out of the car and is handier.
Tmooreheadf
Post by Tmooreheadf » Thu Apr 01, 2021 11:06 am
Thanks for all of the suggestions. I do have the center support and will be using it. Will also be using the standard fourth main shifter, however i have had the e brake after market and it did OK too. I will add adjustments to at least one end.
Post by Original Smith » Thu Apr 01, 2021 11:20 am
Doesn't Chaffins already sell one?
Post by speedytinc » Thu Apr 01, 2021 11:27 am
I also strongly prefer a left side shifter also. Have both styles. Would never install a center shift on a personal car. Unless you have a foot throttle, the center shift requires some juggling to work the throttle & shift at the same time.
Have installed aftermarket left shifters customers. Not that impressed.
Make my left shifters from emergency brake lever units. ($5 @ swap meets). Remove the pawl & lever, weld the holes & grind like they were never there. Mount right behind stock emergency brake. Makes for a really clean set up and easy shift/throttle.
John Warren
Last Name: Warren
Post by John Warren » Thu Apr 01, 2021 2:23 pm
John, could you post a couple of photos, I will be installing my ruckstell soon. Thanks jw
Post by speedytinc » Thu Apr 01, 2021 2:42 pm
Sorry, I am not currently that technicalogally capable.
Post by RajoRacer » Thu Apr 01, 2021 7:21 pm
Search "left hand Ruckstell shifter" - Tom Carnegie from Spokane did a nice pictorial on building one out of an orphaned handbrake a while back - pretty slick !
John Warren
Last Name: Warren
Post by John Warren » Fri Apr 02, 2021 11:08 am
Post by RajoRacer » Fri Apr 02, 2021 11:56 am
You are most welcome !
