Carb adjusting rod
tommyleea
Topic author - Posts: 151
- First Name: Tommy
- Last Name: Russell
Carb adjusting rod
23 T Roadster...Do any of you have problems with your carb adjusting rod, firewall to carb, turning on its own? When I get mine adjusted to where I want it, the vibration of the T seems to make the adjustment turn. I must be missing something that would put some friction on this rod..I don't have a grommet in the firewall. Maybe that is what's missing? Thanks...Tommy
Afrazer
- Last Name: Frazer
- * REQUIRED* Type and Year of Model Ts owned: 1925 closed cab TT. 1925 factory roadster pickup. 1926 two door sedan
Re: Carb adjusting rod
Had the same problem on a Kingston L4 carb. I just replaced the carb adjustment needle clamp nut and snugged it down real good and that solved that problem the remaining time I had that carb on the car. The old clamp nut must have been wore down on the inner diameter and wasn’t holding the needle under driving vibration anymore.
1925 closed cab TT
1926 two door sedan
1926 two door sedan
David nailed it. Just tighten/replace the brass nut that clamps the mixture needle.
tommyleea
- First Name: Tommy
Thanks..Will do..Tommy
Don't go hog wild getting it tight. Snug enough that the rod does not turn on it own, but loose enough that you can still turn it without forcing it.
tommyleea
- First Name: Tommy
Copy..ThanksMark Gregush wrote: ↑Fri Apr 02, 2021 10:28 amDon't go hog wild getting it tight. Snug enough that the rod does not turn on it own, but loose enough that you can still turn it without forcing it.
