touring outside mirror
Emeraude
Topic author - Posts: 87
- Last Name: Loranger
- * REQUIRED* Type and Year of Model Ts owned: 1921 touring
after installing a top on my touring i wanted a outside mirror on the right side. in contacting the vendors none had the clamp on type for the windshield post. I found through amazon a 5 inch mirror that had a mounting post and was able to make a bracket attaching it to the bolt for adjusting the winshield. The mirror was a eckler part #64-21935 was $15.00 thru amazon.
Re: touring outside mirror
I like the looks of it. Sometimes a big splash of brass is too much. It fits the era fine.
Looks good George, even has slotted screws instead of Phillips heads, or did you replace them?
