Identify these if you can plug and timer part
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Wed Apr 21, 2021 12:29 pm
Were these plugs used for military? or some other application ?
the 2nd is a timer part >>>>
thanks for the help, Bob
Re: Identify these if you can plug and timer part
Post by Mark Gregush » Wed Apr 21, 2021 1:11 pm
I have a double contact plug with metal sheath, think it is how some were made by different manufactures. I was thinking timer ring was for a crystal timer, but guess not. http://www.mtfca.com/discus/messages/11 ... 1273895184
FATMAN
First Name: ROBERT
Post by FATMAN » Wed Apr 21, 2021 5:45 pm
Someone told me military on the plug I think but not sure
FATMAN
First Name: ROBERT
Post by FATMAN » Thu Apr 22, 2021 12:51 pm
Any ideas?
Post by DanTreace » Thu Apr 22, 2021 6:28 pm
The plug is typical Ediswan type, with the dual in-line nubs to twist and lock in the socket. Bayonet style.
These plugs could be had in rubber (plastic today) plug or metal banded.
The metal band holds up better, but cost more in the day. Used mostly for plugging to sockets for trouble lamps or dash lamps.
