The final count-down to the 7th Annual Luray Swap Meet.. May 14th and 15th.
James_Lyons-WV
Topic author - Posts: 198
- Last Name: Lyons
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1915 Touring, 1925 Coupe
After months of planning and hard work, the 7th Annual Mid Atlantic Prewar Swap Meet in beautiful Luray, Virginia is now less than two-weeks away! We have 60 vendors coming from 17 different states, and will occupy 109 vendor spots. The long-range accu-weather forecast is calling for partly sunny skies and mild temperatures in the 70’s. It is sure to be a memorable event so you won’t want to miss it! This will be your last update prior to the show, so if you need any information, please go to our website at: www.mapwsm.com for any additional details or contact information. Looking forward to seeing you there!
