ANCO Timer installation question
Mopar_man
Last Name: Govoni
Post by Mopar_man » Mon May 03, 2021 9:26 pm
So I'm installing an ANCO Timer and I want to make sure I'm doing this correctly. I have already installed a modern cam shaft seal and centered the cam shaft cover with a centering tool. So the first thing I did was slip the "roller" on the shaft. Then I placed the pin in the shaft. My question is the washer seems to have a space for the head of the pin but won't slip easily over the pin. Do I tighten the nut forcing the washer on? How tight should the nut be?
Here is the washer
Here it is lined up with the head of the pin.
With the nut finger tight. You can see if I put a wrench on it it would force it on.
Re: ANCO Timer installation question
Post by RajoRacer » Mon May 03, 2021 10:08 pm
Tighten her down - I use Blue Loktite.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Mon May 03, 2021 10:26 pm
Thanks Steve. I'll put some blue lock-tight on it as well.
Post by Mark Gregush » Mon May 03, 2021 11:10 pm
How tight, snug and you should not need any lock-tite of any kind.
Post by RajoRacer » Tue May 04, 2021 11:11 am
Matter of opinion, Mark !
Mopar_man
Last Name: Govoni
Post by Mopar_man » Tue May 04, 2021 2:18 pm
I know Lock-tight wasn't around in 1926 and they probable just made it snug. In this case I wouldn't want the nut to come off. Will it? Not sure but why take the chance. You can still take it off using the blue lock-tight and it will hold better.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Tue May 04, 2021 3:06 pm
I am converting to using location on this nut. I have never used it and never had it come loose, but I will use it from now on. I would rather be safe.
Art Mirtes
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Tue May 04, 2021 3:08 pm
Lock tite not location. Stupid spellcheck
Art M
First Name: Art
Last Name: Mirtes
Chuck Regan
First Name: Chuck
Last Name: Regan
Post by Chuck Regan » Tue May 04, 2021 3:09 pm
Robert, make sure your flapper moves freely. I put a new Anco on my ‘26 and had to file the slot in the pin retainer where the flapper rotates for clearance.
Post by RajoRacer » Tue May 04, 2021 7:10 pm
Cotter pins, bailing wire & Blue Loktite are any antique automobile owner's friend !!!
Mopar_man
Last Name: Govoni
Post by Mopar_man » Tue May 04, 2021 9:19 pm
I pushed down on the flapper and it seem to spring up and down ok.
