Old Front Axle Repair....Masterpiece or Awaiting a Catastrophe ?
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Mon May 10, 2021 7:43 pm
My friend Bill is helping another friend with a 16 front axle. Took the spindle off and found this previous repair to the lower threads. Looks like it was worn almost through.
Anyone else seen such a creation ?
I’d be catching my stomach with my tonsils with every bump if I knew it was there. :shock:
Re: Old Front Axle Repair....Masterpiece or Awaiting a Catastrophe ?
Post by Jerry VanOoteghem » Mon May 10, 2021 8:31 pm
Wouldn't want it in my car... or anyone else's.
pete eastwood
First Name: Pete
Last Name: Eastwood
Post by pete eastwood » Mon May 10, 2021 8:44 pm
I have axles better than that in my scrap pile ,
Come and rescue them before it's to late .
Post by John kuehn » Tue May 11, 2021 8:53 am
Is it some sort of shim, or maybe it was welded up or? Just exactly what is it.
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Tue May 11, 2021 10:02 am
The best I can say without actually seeing it is...
It seems the wedge was fitted to the worn part of the hole and then drilled and tapped.
They are absolutely using another axle. ;)
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue May 11, 2021 2:40 pm
I m going to call it a “Masterpiece of era ingenuity”!! It looks very well done from the pictures!!
I think it belongs in a museum for that reason!
