Firestone 5 lug accessory wheels
Alex Dragone
First Name: Alex
Last Name: Dragone
* REQUIRED* Type and Year of Model Ts owned: 1910 Roadster, 1911 Torpedo, 1915 Touring, 1926 Roadster
Post by Alex Dragone » Tue Mar 12, 2019 8:50 pm
I am looking for period photographs or even current photographs of cars with accessory 5 lug demountable wood wheels with the heavy fellows. I would also like any info about these wheels. This has been discussed previously on the old forum, but some more photos and info would be great! Thanks!
Jim, Sr.
First Name: Jim, Sr.
Last Name: Rodell
* REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
Re: Firestone 5 lug accessory wheels
Post by Jim, Sr. » Tue Mar 12, 2019 10:13 pm
I do not have these wheels, but I do have the special Firestone socket wrench shown in the lower left corner in the ad.
It is available.
1922 Coupe , 1926 Touring
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Mar 12, 2019 11:38 pm
Ed Archer's #4 speedster has 5 lug Firestone wheels on it. IT should be pretty easy to dig up some pictures of Ed's car.
Post by Wayne Sheldon » Wed Mar 13, 2019 3:20 am
Ed's number 4 has Perlman wheels. I do not know just how the companies were related. I have read a few things, but cannot remember enough about the details. Perlman were related to Motor Wheel Corporation (my Paige has Motor Wheel wheels on it). Motor Wheel I think may have been somehow connected with Firestone. The wheels, and lugs, are very similar in design. I remember seeing wheels for Model Ts with a third manufacturer's name. But I cannot remember what that name was. As I recall, there was a series of mergers/divestitures between the companies right around 1919/'20. The Jaxon Wheel Company was also connected to Motor Wheel Corporation. Jaxon, best known for the steel disc wheels used on many General Motors automobiles during the '20s, made both wood spoke and steel disc wheels during the late '10s and early '20s.
The after-market demountable wheels made for Fords hit the market by 1912, at least under the Firestone name. There were differences in the details between Firestone, Perlman, and others. The steel felloe bands were different in both major and minor ways. Some had wood felloes exposed both inside and outside the wheel, with just a steel band around the outer felloe between the wood and the rim. Others had a rolled over edge that covered most of the outer surface of the wood felloe. Wheels without the outer steel surface used "U" shaped metal pieces where the lugs bolted onto the wheel. The size and shape of those "U" shaped pieces varied from one series of wheel to another. The width of the felloe is another difference I recall seeing.
DHarrison
First Name: David
Last Name: Harrison
Post by DHarrison » Thu Mar 14, 2019 12:35 am
Here is Ed's car.
Ed Archer Speedster
Ed Archer Speedster
