I have one coil that sparks on battery but that same coil does not spark when running on magneto. It makes ZERO difference when I place it in the box.
What say you?
Coil problem ?
Will_Vanderburg
Topic author - Posts: 948
- First Name: William
- Last Name: Vanderburg
Coil problem ?
William L Vanderburg
1922 Center Door Sedan
dykker5502
- First Name: Michael
- Last Name: Deichmann
Re: Coil problem ?
Does it buzz on magnet?
Ford Model T 1914 Touring
Re: Coil problem ?
A magneto test might be in order. I'd think a weak coil would do better on Mag at anything above idle.
Will_Vanderburg
Re: Coil problem ?
I recharged the mag yesterday
Re: Coil problem ?
If it buzzes and does not fire across at least a 1/8" gap, it most likely has internal problems. If it does not buzz, I'd look for point problems.
