front spring perch
Rich Huggins
Topic author - Posts: 107
- First Name: Rich
- Last Name: Huggins
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
front spring perch
Hi what is the size of the threads on the pearch shaft that gose through the axel. The head is mushroomed a little and need to clean up with a die, and i need to know what size die i need to buy i think its 5/8 by 20 fine thread but no way of checking
- Last Name: Strange
- Board Member Since: 2013
Re: front spring perch
Rich Huggins
- First Name: Rich
Thank you for your help and i found a die
