Inner wheel bearing race removal advice
catfishunter99
First Name: LORIEN
Last Name: HEGNER
Post by catfishunter99 » Tue Jun 01, 2021 2:54 pm
Hello Forum,
Looking for advice on the preffered method of removing the inner race from the spindle on an early car with roller bearings. I was able to get one side off with some gentle heat and persuasion but not so lucky on the other side. Not looking to destroy the race (or spindle) if I can help it. Haven't seen any info on this in the search just discussion on removing the race from the hub. Any help is appreciated. Thanks!
Re: Inner wheel bearing race removal advice
Post by speedytinc » Tue Jun 01, 2021 6:58 pm
Try 2 wood chisels, opposite sides, in the crack under the race. Can heat first. If it wont come, a couple stubs (like 2 nuts) can be welded to the race. Use the stubs as something to bite on in a press. Repair after grinding off the stubs.
Post by Allan » Tue Jun 01, 2021 8:53 pm
Lorien, when you do get it out, don't be afraid to take a die grinder and make a couple of grooves inside the hub like the later hubs have. That will let you drive out any subsequently fitted cones.
catfishunter99
First Name: LORIEN
Last Name: HEGNER
Post by catfishunter99 » Tue Jun 01, 2021 9:14 pm
Thanks guys! I was able to get it off by welding a couple beads and using a chisel. It is toast but wasn't the best to begin with. Thought I'd keep as a spare but in the scrap it goes!
Post by Steve Jelf » Tue Jun 01, 2021 10:05 pm
Here's what Allan referred to.
