McMillan cylinder head questions
Gene_French
Topic author - Posts: 1103
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
I will be beginning the finish machining operations and rocker fabrication on a McMillan overhead valve cylinder head casting ... many of the operations are clear , standard operations ... i am interested in any information regarding the placement and type of spark plug used ... any photos or drawings of a finished cylinder head would be appreciated ...always an optimist ...Gene French
Tim Williams
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1925 Model T Speedster, 1922 Model t Speedster project
Re: McMillan cylinder head questions
I talked to Chis Becker, and he said he is calling someone who is familiar with the head and should be in touch with you soon.
Tim
Tim
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
My dad has one on the shelf... I’ll snap a couple pics next time I’m over
Gene_French
- First Name: Gene
- Last Name: French
Kevin:
thank you ... pictures would be helpful ... i want to be careful with the spark plug placement since i don't have any info. on foundry patterns and material thickness ... i am certain that the plugs will be centered in cylinders on the intake side ,BUT , may be angled and elevation is uncertain ... any help is appreciated ...always an optimist ...Gene French
