READ Threads Changing Color
Hal
First Name: Hal
Last Name: Davis
* REQUIRED* Type and Year of Model Ts owned: '22 TT Stake Bed, '18 Touring (Hers)
Post by Hal » Wed Jan 09, 2019 12:32 pm
Several people have mentioned it in passing in other threads, but the color of the little icon thingy on the left DOES change color after a thread has been read,,,,,,,,,,,,,,,,,BUT................only after you leave the page and come back. After reading a thread and going back to the 2019 Forum page, it stays the same color. Is there any way to make it change color when just backing out onto the 2019 Forum page?
Hal
First Name: Hal
Last Name: Davis
Re: READ Threads Changing Color
Post by Hal » Wed Jan 09, 2019 12:38 pm
OK, after some experimentation, it appears that if you hit refresh after coming back to the 2019 Forum page, the colors change. Or, if like I said above, if you go to page 2 then back to page 1, the colors change, but not when just leaving a thread and then looking through the list on the 12019 Forum page. It still looks UN-read when doing that.
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Wed Jan 09, 2019 12:40 pm
FWIW - I have also learned that the color change is only evident when you're logged in.
DLodge
First Name: Dick
Last Name: Lodge
Post by DLodge » Wed Jan 09, 2019 1:08 pm
If, instead of using the computer's "Back" button, you click on "Return to 2019 Forum" at the bottom of the page, the screen will refresh and the color will change. I've had to train myself to do that since I am accustomed to using the "Back" button.
Hal
First Name: Hal
Last Name: Davis
Post by Hal » Wed Jan 09, 2019 4:57 pm
Thanks Dick! I'm gonna try that. It may take some getting used to, as I also am used to hitting the back button. But if that works, that sounds like the solution.
DLodge
First Name: Dick
Last Name: Lodge
Post by DLodge » Wed Jan 09, 2019 5:07 pm
Hal, I think that we are slowly demonstrating that, contrary to the conventional wisdom, old dogs can learn new tricks.... :D
Doug Keppler
First Name: Douglas
Last Name: Keppler
Post by Doug Keppler » Wed Jan 09, 2019 5:28 pm
I have a request for Chris, say your on page 2 or 3 and you hit the return to forum button is there any way to make it return to the page you were on instead of going back to the 1st forum page?
1924 Touring car
There's No Substitute for Proper Lubrication
Hal
First Name: Hal
Last Name: Davis
Post by Hal » Thu Jan 10, 2019 7:31 am
I was just gonna say that, Doug. Dick's method was working great. Then I got onto a thread from page 2 and when I hit the 2019 Forum button, it went back to page 1. Maybe having more threads per page will minimize it. Like I said in another thread, I am on other forums that use this or similar software, but I think this one must have 10 times the activity. The others never have more than a single page of new posts, so it's never an issue. Maybe it's because they have 20 different categories you have to sort through. Everything has advantages AND disadvantages, I suppose.
Les Walker UK
First Name: Leslie
Last Name: Walker
* REQUIRED* Type and Year of Model Ts owned: 1925 Tourer
Post by Les Walker UK » Thu Jan 10, 2019 2:27 pm
Press the function key F5.
The screen refreshes and stays on the same page.
( my 6 year old granddaughter showed me how to do it. I'm 77)
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Thu Jan 10, 2019 4:52 pm
You should see the HAMB's (a forum for hot rods) forum page. It has so many users....when you post something, it disappears onto page two and beyond in a matter of minutes.
1924 Touring
MWalker
Last Name: Walker
Post by MWalker » Fri Jan 11, 2019 10:06 am
I just tried the F5 button as suggested above. Many thanks to Les's granddaughter. :)
