Turtle deck
mel.k53
Topic author - Posts: 14
- First Name: MELVIN
- Last Name: king
- * REQUIRED* Type and Year of Model Ts owned: 1915@1923 roadsters
Turtle deck
What bolts wear used to bolt down the turtle deck on a 23 ?
Re: Turtle deck
Don't know what is factory fasteners, any fine thread bolt should work. I just used older bolts from the storage box, with lock washer and square nut on top of the turtle mount bracket to the wood floor of the runabout deck. This is a '24.
R.V.Anderson
- First Name: R.V.
- Last Name: Anderson
Re: Turtle deck
Most likely it was a carriage or possibly a step bolt, with the head under the wood decking; either 5/16" or 3/8" with a square nut and lock washer.
