Welded rods with an A crank
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Post by Bruce Compton » Fri Mar 29, 2024 10:05 pm
I have a very nice 1913 Canadian block (three digit Canadian number) that has had a Model A crank installed. It also has a reground cam, adjustable and later valves and new 0.060 pistons and rings. Looking close at the connecting rods , it appears that someone welded T tops to A bottoms, The rods and crank are beautiful and the engine has run maybe 2-3000 miles and shows very little wear. The weld is right below the wrist pin hole and does not show any signs of fatigue, but I'm wondering if this is accepted and safe practice. BTW, the Main caps are the ones in Lang's catalog. A T buddy that has owned over 100 Model T's says it was a common thing to do, but I'm wondering why someone would not just modify the top of a stock A rod (bronze bushing with retaining clips)?? I believe that A rods and T rods are both 7" C-C. Any comments???? Thanks in advance. Bruce
1915ford
Last Name: Cameron
Re: Welded rods with an A crank
Post by 1915ford » Fri Mar 29, 2024 10:51 pm
Was on a tour years back where a rod broke and grenaded a guys block. Tour over. T rods welded to a rods same as what you are describing. Even before seeing that i just think that trusting a welded rod is not something i would want to try with a block i care about. Especially if you don't know who, or how the welding was performed.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sat Mar 30, 2024 12:31 am
Welded rods are a quite common reality of A crank motors in the pre SCAT crank world. The A rods are 7.500” center distance and require a special piston if not shortened. The special A rod pistons are notorious for pumping oil, and the T tops allow standard piston choices. I’ve made up several sets of shortened A and hybrid T/A rods, and choose to box the rods for additional strength. Welding near the wrist pin is typical
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Mar 30, 2024 11:30 am
Related but not, there were cast aluminum rods available for the A crank in a T block. I actually own a new set and a set of the bearing shells.
Sorry for the diversion!
Bruce Compton
First Name: Bruce
Last Name: Compton
Post by Bruce Compton » Sat Mar 30, 2024 12:25 pm
Les, are they for sale? Bruce
Last Name: Hatch
Post by Dan Hatch » Sat Mar 30, 2024 12:38 pm
Buick 3800 V6 pistons will work. Need special bushings for A rods.
Brian Cress
First Name: BRIAN
Last Name: CRESS
* REQUIRED* Type and Year of Model Ts owned: Speedsters, Roadster, Hack
Post by Brian Cress » Sat Mar 30, 2024 1:45 pm
Dan, are the Buick 3800 pistons "deck height" at TDC, or do they rise above the block like a stock T or A piston?
Last Name: Hatch
Post by Dan Hatch » Sat Mar 30, 2024 2:19 pm
Flat top pistons.
Brian Cress
First Name: BRIAN
Last Name: CRESS
Post by Brian Cress » Sat Mar 30, 2024 3:19 pm
Thank you for clarification.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Sat Mar 30, 2024 3:23 pm
So the Buick pistons work but you have no compression?
Andy
Kenny Edmondson
First Name: Kenny
Last Name: Edmondson
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Roadster PU
Post by Kenny Edmondson » Mon Apr 01, 2024 9:28 am
The Buick pistons work great. There’s a little protrusion above the deck.
Brian Cress
First Name: BRIAN
Last Name: CRESS
Post by Brian Cress » Mon Apr 01, 2024 12:49 pm
Thanks for the picture Kenny.
