Over the last two days, I have disassembled the rear seat box and have transferred drawings to paper. I will be planing down, with the help of another T pard of mine, lumber to fabricate the new pieces. All the box pieces were there with the exception of just a small strip of the rear most riser. I will determine the height needed and make another one. The only pieces I will use from the original are the tacking strips on either side of the box frame and the metal trim that gets covered with cloth on the front riser. I will use the original threaded Fender Mounting Brackets as well, since they are attached to the seat box.
The original wood measures 5/8ths thick for the rear riser heel board and further most riser. The rest of the wood that the seat spring sits on measures out at 3/4ths thick.
Below are three threads I started after having acquired the car. They are from the old forum
http://www.mtfca.com/discus/messages/82 ... 1541873873
http://www.mtfca.com/discus/messages/82 ... 1542064935
http://www.mtfca.com/discus/messages/82 ... 1546478998
1922 Center Door
Will_Vanderburg
Topic author - Posts: 945
- First Name: William
- Last Name: Vanderburg
1922 Center Door
William L Vanderburg
1922 Center Door Sedan
Will_Vanderburg
Re: 1922 Center Door
Center Door work continues
Here's the rear seat box minus the rear board as I don't know the height of it yet.
Also, here's the driver's seat back rest and frame. I have to cut off the screw bolts and replace two of the nuts with square ones.
