Coil Test Tube Ball Bearing Thingy
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Mon Jul 19, 2021 8:06 pm
Somewhere I read the article on how to build this and cannot find it now. I saw one in action at the homecoming and didnt take time to ask about it. For some reason I want to make or purchase one. Anyone have any leads? I dont know the correct name of the thing to do a search.
Thanks in advance.
PS, I am a control electrician and thats why the interest in the odd stuff.
Howard Tomlinson
First Name: Howard
Last Name: Tomlinson
Re: Coil Test Tube Ball Bearing Thingy
Post by Howard Tomlinson » Mon Jul 19, 2021 8:10 pm
Isn't that a electric fence charger?
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Mon Jul 19, 2021 8:21 pm
Been Here Before
First Name: George John
Last Name: Drobnock
Post by Been Here Before » Mon Jul 19, 2021 8:23 pm
Brent Mize
First Name: Brent
Last Name: Mize
* REQUIRED* Type and Year of Model Ts owned: 1927 Sport Touring & 1927 Sport Runabout
Post by Brent Mize » Tue Jul 20, 2021 6:27 am
Here’s the drawing from the Lejay Catalog.
Lejay also made a kit.
Ron Patterson
Post by Ron Patterson » Tue Jul 20, 2021 8:32 am
Here is a photo of the one I have in my coil archive.
LeakyRad
First Name: Don
Last Name: Keil
Post by LeakyRad » Tue Jul 20, 2021 9:33 am
got one that was missing tube found that a rain gauge tube works fine. use glass marble not ball bearing.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Tue Jul 20, 2021 1:34 pm
A Test Tube works great for a glass replacemnet.
Respectfully Submitted,
Be_Zero_Be
Last Name: Hatch
Post by Dan Hatch » Tue Jul 20, 2021 3:13 pm
If anyone does not have a LeJay manual, you need to get one. Lots of info!
That is where I learned to rewind generator armatures. Has info for all types of early auto electrical. You will be surprised what you can make out of a T generator or starter. Dan
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Tue Jul 20, 2021 3:37 pm
Got some things to look for at Hershey. :D
LeakyRad
First Name: Don
Last Name: Keil
Post by LeakyRad » Tue Jul 20, 2021 4:56 pm
the fuse Is a good addition. when I got mine the points were welded together and the springy part witch the ball hits was burned in two. had to make a new one. a rain gauge tube is about the same length as the coil box looks neat except for the numbers. ;)
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Tue Jul 20, 2021 5:34 pm
The "fuse" is actually the glass from a fuse with two electrodes and a spark gap inside.
In addition to the three neon light bulbs, it is an visual display of the spark when the coil fires.
Be_Zero_Be
